Home > Technical (L322) > TD6 engine blown? |
awillia3 Member Since: 04 Aug 2015 Location: Pembrokeshire Posts: 19 |
The engine on my L322 TD6 I think has blown.
13th Sep 2016 12:43pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
Sounds like diesel runaway. https://www.carthrottle.com/post/9liEWT/
13th Sep 2016 9:12pm |
Thank you for the reply, your advice is much appreciated.
13th Sep 2016 9:21pm |
Can't pass opinion on likelihood of this engine being salvageable. A lot of it will depend on whether you're paying labour rates for the work or doing it yourself. A good chance it will be fixable, but will it make financial sense?
13th Sep 2016 10:07pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
This sounds scarey and I feel for you awillia3
13th Sep 2016 11:52pm |
Yes it was scary!! Will update once compression test has been done. If its down at all I won't bother rebuilding the engine. May look at a new engine or even sell the whole car as a project!! Current:
14th Sep 2016 5:51am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
If it's run on its own oil until the engine has stopped itself, the engine is toast.
14th Sep 2016 6:28am |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
As has been said, terminal.
14th Sep 2016 8:50am |
It looks like it was not running on engine oil (turbo failure) as the oil level was very high. The engine isn't seized but it is likely that the seals are all shot and it is very likely that it all overheated!! I have had it serviced once my stealer and once by local garage - not sure if breather filter has been changed though?? Yes new Engine on the cards I think. Current: FFRR 3.0 TD6 L322 BMW M3 E46 Gone: 2002 BMW E46 330d Estate 1997 BMW M3 Evo 1984 SIII Landrover 2.25 petrol SWB Vauxhall Calibra 2.0i Peugeot 205 XS |
14th Sep 2016 4:37pm |
I think you may find that the tips of the injectors have burnt off, and will be pouring fuel straight into the bores (and probably through a Piston or 3)
14th Sep 2016 6:53pm |
I wish I had changed it every service . . . .
14th Sep 2016 7:06pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
My pal had a similar problem with his ffrr, misfiring, new injectors, still over fuelling and filling the sump.... turned out to be a cracked head.....
20th Sep 2016 9:47pm |
