Home > Technical (L322) > New pipe
Madmutt0
New pipe
Hi can anyone give me a part number for the blue pipe in picture or tell me what I need to ask for mine s a little frayed and will need replacing soon
Post #404275 10th Sep 2016 4:11am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
I assume you mean the thin blue vacuum line in the background of that photo?
In which cases it's LR001848 described as 'Hose - Vacuum, Blue'.
It's the Secondary Air System control hose from the solenoid to the SAS valve.
If it's the end that's just frayed cut back to good and re-insert as long as you have enough length.
Other wise any vacuum hose of the same diameter will do and be ten times cheaper than the LR part.
Post #404290 10th Sep 2016 9:07am
Madmutt0
Pipe
Thanks wee jock yes that's the pipe and you are right it's starting to fray
Post #404303 10th Sep 2016 10:31am
Madmutt0
Pipe
Hi you wouldn't know the pipe diamater by any chance thanks
Post #404411 11th Sep 2016 4:40pm
