Home > Technical (L322) > Which setting to use for snow... |
You should leave it in high range if you are doing normal driving in the snow - if you dont you will have too much torque going to the wheels and it will want to spin.
1st Dec 2010 12:19pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 |
GGS in high range should do for most driving |
1st Dec 2010 12:25pm |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
cheers guys, I did wonder.
1st Dec 2010 12:31pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
You should be able to leave it in high or low range for any of the terrain response settings.
1st Dec 2010 12:41pm |
scene247 Member Since: 16 Sep 2010 Location: London Posts: 126 |
Yes, you can select GGS mode and leave it in high range. Can also select this mode while on the move. With regard to the slip/slide, not sure about that, but main differences are the throttle response is reprogrammed and reduced to minimse the wheels spinning, also the car will start in 2nd gear for lower torque and thus again reduce chance of spinning wheels.
1st Dec 2010 1:17pm |
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 |
Was Terrain response only on 2007 and later ? I thought i was going mad |
1st Dec 2010 4:59pm |
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 |
yes, I believe it was. '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
1st Dec 2010 5:20pm |
