Home > Duckworth Parts > Evaporator & Associated Parts
SteMY06HSE
Qatar 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Morning Dan,
Been having a spot of bother with the a/c and my local LR dealer has said its a leaking evaporator. I am still trying to research it a bit further as he was quick to diagnose it and didn't really give me anything conclusive. Its going to be a winter job here so I am doing my research and working out the cost while I wait for the weather to cool down.
So if I am going behind the dash to replace the evaporator, I am only going in there once so can I get a price on the following items please:
JDQ000050 Thermostatic mixing valve
JQB000160 Evaporator
JUE000390 Hose to evaporator
JTF000040 Sensor, Heater temp control
Just in case, can you also give me a price on the blower motor housing (the big black lump... might be part number JEC000315. I know its going to be costly and if you know the shipping weight that would also be good), I think a previous owner has been meddling with it so who knows what I will find.
Finally... the control unit in the dash is playing up, think the rotary buttons are worn out as the thing has a mind of its own, so thinking about swapping that over at some point. Already changed the FSR and its still the same.
JFC500011PUY is the number I can find for RHD but I will need a LHD version with centigrade values and without seat heating. I seem to recall reading somewhere that if you change this you need to configure it with the dealers T4, is this correct or can you just swap it out?
I will PM you the VIN number, its a middle east spec vehicle if that makes any difference to the a/c bits. Topix has it listed as having a high output a/c compressor.
Thanks in advance,
Ste
Post #403988 8th Sep 2016 8:22am
