![]() | Home > Maintenance & Mods (L322) > 4.4 v8 m62 tensioner |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Well, seeing as you asked, read this,
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
If you've got a rattle it's worth trying it first. If you haven't got a rattle don't bother.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Hi weejock
Yeah that's the same as me now...after I put a new tensioner in lol!
How many are there the guide is confusing shows one but mentions multiple?
There is the main timing chain tensioner which you access from the outside of the timing case and takes up the main slack of the chain. The others mentioned would be the camshaft timing chain tensioners which sit inside the timing case in between the camshaft spockets, you need to strip everything down to replace those and they don't usually cause problems.
there are two non return valves, one behind each vanos solenoid. fairly simple to do. i think you use an allen key to extract them. (carefully)
