![]() | Home > In Car Electronics (L322) > Bluetooth and DAB |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
Yes, it's a MOST system, so the previous owner will most likely bypassed the BT module on the fibre loop.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
its one of the taboo's of owning the 2005-2009 most touchscreen FF's Pete...
Biffo Member Since: 26 Aug 2016 Location: Wiltshire Posts: 82 ![]() ![]() ![]() |
Thanks for that - so DAB would have to be an aftermarket add on - I can live with that.
Take a look here http://www.fullfatrr.com/forum/topic33418.html?highlight=wiggs Got - 2017 SDV8 Autobiography in Loire Blue
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Is the cradle not just that, a cradle?
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
2121 is corect. It may be that the BT unit, if there is one, needs re-flashing. I had to do mine. Used the Gap iiD tool. John
The Nokia module is toast - I could see faint copper staining round the pins in the unit so cleaned it up carefully, reconected the fibre and everything stopped working - just got the Land Rover screen ! I've re joined the fibre as it was previously and all works again. So I'll be on the lookout for the later module to fix and upgrade it |
