Home > Off Roading & Green Laning > Overlanding L322 build, reliability and technical |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
Have a read of this mate
4th Sep 2016 6:33am |
royalgoldfish Member Since: 04 Sep 2016 Location: Melbourne Posts: 30 |
cheers mate, that answers most of my questions, just got to sort out the engine and technical stuff Don't let school get in the way of your education |
4th Sep 2016 6:39am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
There are a couple of members on here from down under who have used their FFRR off-road - there is an Australia section from the main forum index which will be worth a read
4th Sep 2016 7:44am |
Just had a flick through those, a shame about the shocker failing and that was a brilliant build on the green one. Wondering just about reliability after that hahaha but seems pretty doable considering he did 16k miles with a set of 32". Cheers for all the posts Don't let school get in the way of your education |
4th Sep 2016 8:48am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Ross has already directed you to my build thread...
4th Sep 2016 5:37pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
^^^you will NEED an IID tool anyway for such a (fantastic) project indeed, worth it weight in gold if you breakdown in the bush! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
4th Sep 2016 7:27pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 608 |
I think if it's an off road toy as Pete's is you'll be fine. I made the mistake of using a TDV8 as both an off road toy and daily drive. Whilst doable it wasn't cheap. The main problem I've had is tyres but then the TDV8 has Brembos all round so some want limiting on tyre choice.
4th Sep 2016 8:05pm |
Ed, I run mine as a daily driver, done 34,000 miles in it in 2 1/2 years, run the last few months on muds, just need to turn the volume up....
4th Sep 2016 9:38pm |
Pah, try 25k a year and that wasn't using it all the time.
4th Sep 2016 10:08pm |
thanks haylands, i will go for the programmable IID then, i don't plan on being rough at all and i will be following that snorkel build very closely so i don't drown mine either. Just as note I would be lucky to put more than 3k miles on it in a year. Any other recommendations in terms of choice, iv heard the V8's are more reliable than the TD6 both in gearbox and engine
4th Sep 2016 11:36pm |
Given the gearbox issues you're probably wise to avoid the Td6. Although I don't know what's on the 4.4 - I'm guessing a ZF box?
Perhaps I'm just lucky but both the Series I rebuilt and the 110 have pretty good heaters, cooling effect no but pretty damn good at heating. I just need to finish adapting the L322 seats that I got off miggit and then will fit them inside the 110, front first, rear second. Got all the motors working but admittedly haven't tried the heated element yet. Ed |
5th Sep 2016 7:39am |
Yeah it has a ZF box, if all goes ahead ill actually go for something a bit smaller in the 16" range (custom built if need be), In australia we don't have trails quite like yours from what i hear, and the width of lancrusiers and patrols running 37"making trails arnt uncommon down her either. Don't let school get in the way of your education |
5th Sep 2016 7:58am |
You can't fit anything smaller than 18" wheels as the brakes and calipers are too big...
5th Sep 2016 11:38am |
Your a blessing mate, just a wealth of info, theres a couple CNC places here that reckon the can can make a concave set for 16 inch that can clear the big brakes (that was my original plan) but if i get the truck ill tell you how that goes. Unfortunately whatever it ends up costing ~2k aud ill probably just do it as its kind of necessary down here because the sidewalls is a must when airing down on the sand and thick stuff.
5th Sep 2016 11:43pm |
