Home > General > L322 from 3.6 Tdi to 4.4 Tdi?
Ideally they should move to SC and Turbo but that's not likely to happen with them getting every possible penny or of each car these days FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #403281 4th Sep 2016 3:53pm
mjdronfield
I read it here, in this thread, but ive seen the same text in a press release somewhere....
http://www.fullfatrr.com/forum/topic38060.html?highlight=4+4+tdv8
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #403283 4th Sep 2016 4:06pm
There you go then that settles that. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #403297 4th Sep 2016 6:23pm
To me that is describing the SDV6 be the tdv8(3.6) setup... I don't see mention of the 4.4 setup really FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #403302 4th Sep 2016 6:50pm
GraemeS
Australia
The 3.6 has 2 matching turbos with 1 turbo feeding each bank in the same manner as the 2.7 TDV6 as originally fitted to Jags. The 4.4 has a primary turbo on the right bank feeding both banks and a smaller secondary on the left bank contributing when operating, similar to the 3.0 TDV6 although the 3.0 TDV6's primary turbo is on the left bank and secondary on the right bank.
Post #403315 4th Sep 2016 8:50pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Have owned both the 3.6 and 4.4.
For me when owning these cars, the primary consideration should not be ticking time bomb / fear mentality of what can go wrong.
Touch wood I have had no serious problems with either the 3.6 or the 4.4.
My current 4.4 runs like a dream.
No comparison with the drive with the 3.6.
Post #403316 4th Sep 2016 8:53pm
Greame do you have any backup info for this at all as I'd be interested in seeing how it's all plumbed in Smile 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #403319 4th Sep 2016 9:10pm
GraemeS
Australia
These diagrams from the D4 workshop manual are for the 3.0 TDV6 so the primary and secondary turbos are on the wrong sides for the 4.4 TDV8 and the 3.0 has a single air-box whereas the 4.4 has 2, but otherwise show the flow. The first diagram isn't quite correct because the turbine shut-off valve (2) prevents exhaust flow through the secondary when closed yet the diagram shows that exhaust gas still flows, but perhaps a small flow still occurs.
Primary only
Both
Post #403332 4th Sep 2016 10:40pm
mzplcg
Whale oil beef hooked. I've learned so much in the last set of posts. What a fine and knowledgeable bunch of chaps you are Thumbs Up
Post #403386 5th Sep 2016 11:09am
JohnJ
Italy 2011 Range Rover Vogue 4.4 V8 Santorini Black
thanks so much for all the comments... I am very tempted to the upgrade to 4.4 since 405 is out of budget and honestly, too flashy for my taste... but my 3.6 interiors do tend to show the passing of time too much for my taste...
Just the fact that this particular 4.4 on sale at LR had the engine blown up and replaced, with the 2 turbos, is kind of frighting me out of it... I assume they did replace that engine on guarantee for the previous owner but they will not to that again.
As a lot of comments went on the turbos... now it is clear that they are sequential, but are they still placed in that unlucky position under the engine so you need to take the car apart to replace them? I guess so since it was mentioned there is one for the left and one on the right hand side....
Just a side note, I checked other vehicles such as Q7, X5 and GL....more for curiosity and I must admit that none could match the driving position of the Rangie, by far! it is addictive!
Post #405468 19th Sep 2016 8:53pm
mjdronfield
I've not seen much regarding turbo issues on the 4.4. The 3.6 yes, but not the 4.4.... yet anyway....
They are different turbos in a different setup. Still underneath I think though.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #405476 19th Sep 2016 9:09pm
