![]() | Home > In Car Electronics (L322) > No sound??? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
check the volume, obvious but i need to ask,
Mart67 Member Since: 26 Apr 2016 Location: West midlands Posts: 45 ![]() ![]() |
Yea, I did a quick Google search and seems a common issue that is sometimes resolved with a battery reset. I have checked the volume just incase but still nothing?
another possible problem could be water ingress in the electronics cubby hole. ... - .- -.
Yea it appears they suffer with water getting in and upsetting all the modules in the rear left compartment. |
Right then, fuses checked, and battery disconnect done but still no sound. Is the amp right at the back in the cubby hole under the nav drive and DVD player??? |
Try wiggling the two speaker plugs on the top of the dsp module with the radio on. Lost the sound on mine as you have and I found it to be a bad connection in one of the plugs. Cleaned the connections up and all has been well since. |
Is the dsp module the first module below the DVD player?? |
Yes the black vertical box at the rear below the sat nav. You need to be looking at the two plugs on top nearest the centre of the car. |
I will have a look at this tommorow and get some pictures posted. Cheers |
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 ![]() ![]() ![]() |
I had same problem. Water/damp had damaged my amp. Found one on fleabay for �180, worked fine. Year later it stopped working and same problem, water damaged. Pulled out the boot cover and my boot was inches deep in water, I had never noticed.
OK Gents,
Can anybody shed any light on this issue? Appears common when you check google?? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Yes & yes sir... The MOST ring will try to boot up until you find the one (or more) modules now not working... May i suggest you go through and check for bad plugs (water contaminated/green) and report back with your findings... Usually there will be some age/condensation/water ingress damage on a FF of your age and once the �bits & bobs� in the rear corner have been disturbed! Your issues can be found ![]() |
Right then, had another good go today, good news, all back up and running, no signs of any water but still no sound!!!!
