Home > Technical (L322) > Lower glove box issue |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Has no-one ever had this problem then? Got - 2017 SDV8 Autobiography in Loire Blue
5th Sep 2016 8:12am |
Alan, not had this myself but I did go through te indignity of being unable to open the lower glovebox. (flat battery) If you want a laugh actually, read here http://www.fullfatrr.com/forum/topic2588.html?highlight=let
5th Sep 2016 10:31am |
Cheers for that, I did wonder about the opening mechanism taking too much current but it "blows" as soon as I turn on the ignition rather than when I hit the button to open the box.
5th Sep 2016 2:38pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Alan did you ever get a resolution to this as I am in a similar position with the same symptoms |
12th Feb 2018 7:29pm |
Sadly not, no. I have another new switch but I haven’t had the time, or the decent weather to check for a pinched wire somewhere behind the dash. Got - 2017 SDV8 Autobiography in Loire Blue
12th Feb 2018 7:43pm |
Well I have the same after having the box out to install steps so my glove box is in my office will have a look next weekend if I find anything will let you know |
12th Feb 2018 7:56pm |
Mine started when I ran a power cable to feed an external sat nav, so I’m convinced it’s a pinched cable somewhere tha I just need to find. Got - 2017 SDV8 Autobiography in Loire Blue
12th Feb 2018 9:27pm |
jncunliffe Member Since: 01 Mar 2013 Location: Dorset Posts: 8 |
Hi, I don’t suppose you ever solved this one did you?
22nd Jun 2019 4:16pm |
Put a new switch in all fine |
22nd Jun 2019 4:32pm |
Thanks. I’ll give that a go. Still can’t see why it’s needed but that’s Land Rovers for you..... |
22nd Jun 2019 6:16pm |
I tried several new switches and each time it burns out. Got - 2017 SDV8 Autobiography in Loire Blue
22nd Jun 2019 10:48pm |
That’s not very reassuring. Anyone any ideas...? |
23rd Jun 2019 7:39am |
Hi,
24th Jun 2019 9:37pm |
Good find! Only JLR could give such a simple device a complicated name
25th Jun 2019 9:48am |
