Home > In Car Electronics (L322) > Alternatives to OEM IR Headphones
TimperleyRR
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
Hi All,
I am looking at options for the 3rd set of headphones for the RSE of my 2006 L322. So far my understanding is that the same units were used from 2005-2012 and were originally manufactured by sony. Searching the LR part number comes up with offerings well over £150 which is too much to swallow.
I have also seen boards suggesting that almost any dual channel IR headphones should work? Can anyone with experience of this confirm please.
Post #402474 29th Aug 2016 7:22pm
TimperleyRR
In an attempt to answer my own question:
A closer look at the headphones supplied second hand with my own car (which I had assumed were LR originals and which look remarkably similar) show that they are made by Rosen.
They are for sale new on amazon for £40 and one add specifically brands as RR:
https://www.amazon.co.uk/Range-Entertainme...B00LZRL81W
I am pretty sure that other cheaper alternatives will work such as these which advertised the correct frequencies:
https://www.amazon.co.uk/Adjustable-Univer...headphones
I have opted for the first ones and will post up if they work.
Post #402638 30th Aug 2016 5:30pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi mate, yes not worth getting genuine ones...
I went for these: https://www.amazon.co.uk/gp/product/B00O9M...&psc=1
Look like the same ones as you posted. Can confirm they work brilliantly and have dual channel too!
Defo would reccomend. Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #402669 30th Aug 2016 7:52pm
TimperleyRR
Just to confirm that the rosen IR headphones (https://www.amazon.co.uk/Range-Entertainme...B00LZRL81W )
worked just fine and were extremely similar to the original OEM pair I got with the car. Pretty sure the others would have worked as well.
DO NOT WASTE MONEY ON ORIGINAL HEADPHONES Exclamation
Post #403112 3rd Sep 2016 7:47am
