Successful conclusion to my sunroof adjustment problem!!! | |
After replacing the battery some months ago I carried out the usual re-set procedures with the windows, the steering wheel lock-to-lock and the sunroof, all of which seemed to work. However, I noticed after this that the rear of the sunroof was well below roof level and tried re-setting again with the same result - the sunroof worked correctly but its 'at rest' position was front level, rear 5mm below the roof. After trolling through a number of posts on this and - ahem - other sites it seemed that I would have to adjust the glass with the screws, but I came across one post that suggested holding the button in the raised (ie re-set) position for at least 45 seconds. This worked and the roof is now correctly adjusted, but I dont understand why there seems to be more than one at rest position. Seems the only thing to do if yours has this is to keep trying the reset until the roof is level...... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
