Home > In Car Electronics (L322) > 2004 vogue DSP connectors
Bobpm45
Hi all, I am trying to rewire the 18 pin connector plug ( co492) on my 2004 vogue with DSP and built in phone , due to the dreaded corrosion ! I got a bit mixed up with the pinouts and when I referred to the workshop manual it showed 8 wires, whereas mine has 9 ! I noticed that the BMW forums were showing a 9 wire pinout diagram but wondered if anyone can help with the l322 pin out arrangement.Thanks in advance.
Post #401938 25th Aug 2016 11:07am
markcartlidge
if you pm me you email I will email the elec cct pdf for 2003my if it helps 6.41mb
Post #401951 25th Aug 2016 1:00pm
Bobpm45
Thanks for that. However, I cannot PM anybody yet as I have less than 3 posts apparently ! Bob
Post #401953 25th Aug 2016 1:22pm
Bobpm45
To add to the confusion, the electric circuit diagram only shows 5 connections for this plug ! pin 5 the i-bus wire, pins 8,9,17 and 18 the pre amp wires from the BM54 unit . The four wires not shown appear to be for the telephone . The workshop manual states they are for Telephone audio negative,Telephone audio positive, and Telephone on.The 9th wire is shown on the BMW forums as "telephone mute".
Post #402028 26th Aug 2016 7:23am
Zulu 10
*** Treat With Caution - Content Not Verified ***
In my dealings with my DSP this week, this is what I found on a BMW forum:
The pinouts for the 15 pin connector, the one with the large pins and the slide lock connector.
Connector 491
1. Subwoofer Rear Deck, Left +
2. Subwoofer Rear Deck, Left Center +
3. Left Rear Door Woofer -
4. Radio on/antenna trigger signal (12v)
5. Right Rear Door Woofer +
6. Subwoofer Rear Deck, Right -
7. Subwoofer Rear Deck, Right Center -
8. 12 V Power Source
9. Subwoofer Rear Deck, Left -
10. Subwoofer Rear Deck, Left Center -
11. Left Rear Door Woofer +
12. Right Rear Door Woofer -
13. Subwoofer Rear Deck, Right +
14. Subwoofer Rear Deck, Right Center +
15. Ground
Here are the pinouts for the 18-pin connector:
Connector 492
1. Not used
2. Low freq. negative (-) signal - Transceiver/charging electronics
3. Not used
4. Not used
5. I-bus Signal Line - Splice X18344
6. Not used
7. Not used
8. Right Preamp Output – (*** Possible Translation Error: By this I think they mean the pre-amp output that is fed to the DSP as its input - applies to three similar 'outputs' as well)
9. Left Preamp Output –
10. Not used
11. Low freq. voltage (+) signal - Transceiver/charging electronics (DSP)
12. Not used
13. Telephone mute signal - Transceiver/charging electronics
14. Not used
15. Telephone ON signal - Transceiver/charging electronics
16. Not used
17. Right Preamp Out +
18. Left Preamp Out +
Here are the pinouts for the 26 pin connector:
1. Left Front Woofer +
2. Left Front Woofer -
3. Not used
4. Right Front Mid-range -
5. Left Front Mid-range +
6. Not used
7. Not used
8. Not used
9. Right Front Mid-range +
10. Left Front Mid-range -
11. Right Rear Mid-range +
12. Right Front Tweeter +
13. Right Front Woofer +
14. Left Front Tweeter +
15. Left Front Tweeter -
16. Left Rear Mid-range -
17. Not used
18. Not used
19. Left rear mid-range speaker/tweeter +
20. Not used
21. Not used
22. Not used
23. Not used
24. Right rear mid-range speaker/tweeter -
25. Right Front Tweeter -
26. Right Front Woofer
Does that help, or add further confusion? My electronics units are currently spread out over the boot, so if you have a question relating to a specific wire colour then reply on here and I'll check periodically through the day...
Post #402030 26th Aug 2016 7:38am
Bobpm45
Thanks . Thats the pinout I saw on a BMW forum , so I will go for that.
Post #402031 26th Aug 2016 7:42am
Bobpm45
Now if I only had the colours of those 4 telephone wires to make sure I get them right !
Post #402033 26th Aug 2016 8:01am
Zulu 10
Can you wait an hour or so whilst I go and scribble down the colours for you? Don't risk mis-connecting, 'cos if you stick 12V up what is intended to be a TTL input you may cause damage.
Post #402035 26th Aug 2016 8:11am
Zulu 10
Is this what you need?
I count nine cables...
Post #402037 26th Aug 2016 8:43am
Bobpm45
Great ! Many thanks.
Post #402040 26th Aug 2016 8:55am
Bobpm45
I now realise where I was going wrong ! I was reading the pinout diagram upside down thinking they were showing the pins on the dsp when actually they are showing looking at the plug from underneath . (if that makes sense !)And therefore the i-bus wire was in the pin opposite , and thats why i can't get the dsp to show up on the screen !! Once I get the connector sorted I will let you know if i get my sound back.Incidentally, I have obtained a spare Dsp out of an X5 2004 model. Will I need to get it programmed for the L322 ? either way I got an auction bargain ! A DSP , a six CDchanger, a ULF module with passkey 7th gen., a subwoofer , all for £10 !!!
Post #402054 26th Aug 2016 10:26am
Zulu 10
That really is a bargain.
Regarding coding a DSP: I have read, as I assume have you, a lot of conflicting information about the need to code DSPs.
What I do know is that when I use NavCoder to interrogate the DSP I do get a set of tell-backs (including the last six chars of the VIN)
I think, and it really is only 'think' that the coding to the car alters the DSP's processing algorithms to optimise the sonic experience according to the acoustic characteristics of the car.
I think also it alters the speed vs volume graph, and a few other settings.
From all my digging, and I Bus recording, I can find absolutely no indication that a DSP will refuse to work if it discovers that it isn't fitted to the type of car that it thinks it should be.
That said, if it expects to see a Head Unit (Bordmonitor), a Nav Unit and a Radio (BM54) then I know from experience that it will throw a hissy fit if it realises that one or other is missing.
Post #402055 26th Aug 2016 10:33am
Bobpm45
I already have a bid of £20 for the subwoofer , so am now in pocket !!
Post #402056 26th Aug 2016 10:36am
Bobpm45
All sorted ! Wires correctly pinned out as per your photos zulu 10, and X5 dsp fitted, just in time for my trip to Barmouth in Wales on saturday morning ! Unfortunately I had to turn the music off halfway as my wife couldn't stand the "trance " music bellowing out ! Ah well ! By the way Zulu 10, can you supply your christian name as I write articles for the Range Rover Register club magazine and I would like to mention your help in my next one. Cheers, Bob
Post #402511 30th Aug 2016 7:23am
Zulu 10
Glad it works Bob, as now does my iPod and touchscreen install. There's honestly no need to mention me in your magazine, but if it pleases you then, in the words of Paul Simon, you can call me Al.
Post #403003 2nd Sep 2016 6:41am
