Home > Technical (L405) > Loud whistle/whine from rear of car
Hobo729
Cyprus 2019 Range Rover Autobiography SDV8 Baltic Blue
I am experiencing a loud noise from the rear of the car when the vehicle has stopped and the engine/ignition is off. It sounds like a very piercing whistle/whine type of noise and continues for a couple of minutes and then stops. This happens every time the car is used and seems to be getting worse. Is it something to do with the air suspension pump I ask myself?
Post #400807 17th Aug 2016 8:40am
Doodle
So do you lower to access height before stopping engine or do you stay at road height.
Sounds as if compressor is doing its job. Sometimes I hear a faint whistle under similar circumstances to yours after I lower to access.
Post #400824 17th Aug 2016 10:01am
Hobo729
Loud Shrill Whistle
Hi Doodle - no I just leave the car at road height and drop out Cool
I have traced the noise is coming from somewhere in the vicinity of the rear right hand corner of the spare wheel enclosure - I decided against going further and getting a hernia from removing the wheel - I may have to go to the 'stealer' for them to remove the problem and my wallet Big Cry
Post #400870 17th Aug 2016 4:15pm
lucky
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
hi, there is currently a recall from LR to do with potential faulty suspension compressor, they replaced the compressor silencer on mine last week.
its probably worth contacting LR to see if your car might be affected
Post #400926 17th Aug 2016 9:49pm
Hobo729
Solved!!
After 30 minutes checking the suspension and the compressor, the technician noticed the electric towbar indicator light on the switch was blinking and it would appear that the noise was an alarm to tell you it wasn't fully stowed. It was fully stowed but the system wasn't aware of that, so a system reset and re-program corrected the issue. €70 went out of the wallet but I did get the re-set instructions if it happens again.
Happy days Cool
Post #401530 22nd Aug 2016 8:47am
Laughing Thumbs Up All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #401541 22nd Aug 2016 10:47am
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Ah hah, I had my electric towbar on a previous car do this. I followed the reset procedure several times (it is in the user manual) to no avail. However, mine was warning permanently and too annoying to drive. LR Assist came out and could not reset even with computer and the car was deemed unrepairable. A courtesy car supplied and a complete new electric towbar assembly fitted to cure it.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #401547 22nd Aug 2016 11:29am
Thumbs Up nice Nick Smile All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #401558 22nd Aug 2016 1:22pm
