Home > Technical (L322) > Vibration 4000rpm all gears |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2288 |
does it feel/sound like driving over a cattle grid?
22nd Aug 2016 6:31pm |
hgbosch Member Since: 27 Mar 2015 Location: Pretoria Posts: 15 |
Unnecessary quote removed
22nd Aug 2016 7:27pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I would have thought that would make more sense than drive shaft as a drive shaft will be rotating at a different speed depending on gear whereas the TC rpm is related to the engine RPM, I think. Engine mounts might also be worth a check |
22nd Aug 2016 10:22pm |
DocD Member Since: 11 Mar 2015 Location: Johannesburg Posts: 12 |
It does feel a bit like a cattle grid, the entire vehicle vibrates. Thanks guys I'll have it checked out, and will keep you informed. |
23rd Aug 2016 5:13am |
I don't know whether trying it in sport mode if you have one or manual will get the torque converter lock up clutch or valve body doing something different but no harm in trying. RRPhil is your man for transmissions. |
23rd Aug 2016 7:13am |
No difference in sport or normal drive mode, it banters from about 4000 to 4500 rpm then settles again. |
23rd Aug 2016 11:15am |
if it's the TC you might try a total gearbox flush including the TC. That's about two liters more oil as the gearbox allone. It did it for me once. |
23rd Aug 2016 11:47am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Have you confirmed, that when you get the vibration, ,if you were to manually change down the gears, to say a higher revving gear, you get more vibration? If it's at the speed that 4000rpm comes in, and if say bringing the engine speed down, it still vibrates, then, surely the vibration, is something other than the engine.
23rd Aug 2016 1:37pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
This may be a bit off-base, but are there any flexible joints in the rear propshaft?
23rd Aug 2016 4:19pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
If it's engine speed related in any gear then it can't be propshafts or driveshafts or fuel pump....They do not move at the same speed as the engine in different gears... AFAIK the TC issue happens at lockup speed and that isn't anywhere near 4000rpm in an SC...
23rd Aug 2016 6:06pm |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
I was thinking if he is running this up to 4k rpms often the vibration could be passengers shaking in fear. That's in the "holy crap" range for me. |
25th Aug 2016 6:14pm |
Taking it in to a gearbox specialist on Monday, will keep you all informed.
25th Aug 2016 6:30pm |
