![]() | Home > Technical (L322) > Rear fog light trailer module |
Bingy Member Since: 09 Feb 2015 Location: Colne Posts: 23 ![]() ![]() ![]() |
Two years ago i fitted a tow bar with dedicated electrics for the two 7 pin plugs from PF Jones.
Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48 ![]() ![]() ![]() |
Has your new tin tent got led rear lights ? |
No All Bulbs |
I had similar issues with the 13 pin to dual 7 pin adapter cable on a Disco 3. Nothing wrong with the cables, or teh car, or indeed the caravan. But the combination of all 3 led to lots of bonging and warnings about bulbs being out. I changed the loom on the car to a 13 pin one (not expensive and is plug and play) and it was all peaceful again.
Yes mine all worked fine on dual 7 pin plugs for 2 or so years.
You can remove it if necessary. A 2 minute job. But this is likely to be fixed with the correct cable. Mine was. |
So i ripped out all the old twin sockets and wiring, together with the towing module.
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
You can buy a converter that plugs in to the 13 pin socket and has a 7 pin socket for your trailer.
