![]() | Home > Maintenance & Mods (L322) > Dedicated Starter Battery |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1552 ![]() ![]() |
niceday, my concern about the cable is, as Wayne pointed out, about chafing. I don't do much (any) real off-roading anymore but I do travel on rough, corrugated dirt roads. I would also fit a circuit breaker at the rear. The breaker is cheap compared with burned wiring. I have got one the same as the one Wayne shows above somewhere put in the garage. Best I have a look for it!
I presume if anyone wants to fit a battery in the rear compartment and is concerned enough about hydrogen gas it would be a fairly simple matter to arrange to connect small diameter plastic tubes to the battery vents and run these pipe out below the car into fresh air by way of a rubber grommet. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
Nice write up and well executed, top job mate..... |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Hi Pete, and you are right on the money.
Thanks for your positive comments gents. |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
I wouldn't worry about it. Both my Volvo and BMW estate cars have their batteries in the rear and no vent tubes at all. And back in the day my old VW beetle had the battery under the rear seat, ![]() |
I'm not worried about hydrogen, just corrosive acid. Ron B. VK2OTC
Well after fitting a second battery in the rear compartment and having had no problems whatsoever I decided to put my idea of using the original front battery as a dedicated starter battery to the test.
I recently had to replace the two 12v 45Ah deep cycle VRLA batteries in my wife's mobility scooter.
I just have to decide whether to use an Electronics Australia (magazine) dual battery controller I built many years ago and took out of my old RRC, or to buy one of Tim's (drivesafe) Traxide kits. I had a Traxide SC40 dual battery controller in my P38A. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA Last edited by p38arover on 30th Dec 2016 6:19am. Edited 2 times in total |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2638 ![]() ![]() |
Will the VRLA batteries tolerate the car's charge voltage? |
Hi Graeme and yes because all new AMG batteries are now designed to tolerate charging voltages up to 14.7v.
The batteries I bought are Neuton Power NPD12450 12V 45Ah VRLA (Deep Cycle) with Terminal Type T4. I got them from YHI Power who have offices in Oz's major cities. Ron B. VK2OTC
Ok along these same lines has anyone thought about saving weight and using some supercaps as a battery storage unit in the rear with front isolator?
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Hi,it seems from what I've read from car sellers, a vsr needs to be connected positively between both batteries,surely this necessitates a physical dedicated cable running all the way from front to rear? |
