Home > Maintenance & Mods (L322) > Gearbox oil change |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Might be a good time to ensure the oil cooler is all clear, you are going to have to disconnect it to get the box out (?)
13th Aug 2016 10:06am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8325 |
You can also drain all the oil out of the torque convertor which is where the oil gets stuck when normally draining it out, it's a pain to do as you can't just pour it out, you have to keep tipping it back and forth...
13th Aug 2016 11:31am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
How sure are you, that the rear seal is indeed leaking.
13th Aug 2016 1:21pm |
Madmax676 Member Since: 25 Jun 2016 Location: Somerset Posts: 44 |
Hi all
15th Aug 2016 7:52pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8659 |
If you are splitting the box off and can get the TC out then there is no benefit in power flushing the box, the idea of which is to make sure all the oil is changed.
15th Aug 2016 8:01pm |
kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85 |
I would change TC like Pete says. It is considered as wearing part. I did change it on mine when engine was off. -08 3.6 Vogue
16th Aug 2016 6:55am |
