Home > General > Mileage: 170,000
Mileage: 170,000
Yes, just passed the 170,000 mile mark today Very Happy
(searched and searched for my "annual thread" on this but couldn't find so starting again!)
When purchased in Jul 08 car had done 87,000 (so averaging @ 14.5K a year)
Now the average is @ 11.5k
I have averaged @10.3K
Oh, and it passed its MOT without any failures, though tester starting to get worried about rust on front and rear subframes, one rear wishbone, and I have not had the plastic covers off the sides yet to look at what is going on with the sills and jacking points. Plenty of bubbling in the rear door frames, and LHR wheel arch, rear quarter panel and LH boot edge. So much to do and so little time Smile .
Post #398867 2nd Aug 2016 5:23pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
just run in joe Thumbs Up
Post #398868 2nd Aug 2016 5:27pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Not far beyond - just turned over 164,000 this evening - doing 22k a year. Sailed through MOT last month with just an advisory on a rear suspension bush. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #398893 2nd Aug 2016 7:45pm
Front and rear subframes are the things that will go, i've spotted even on mine while it may be surface rust it still gets in.
Probably best to find used ones and then sandblast then primer and paint up as swapping over shouldn't be too bad Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #399006 3rd Aug 2016 3:20pm
I have less fear about dropping the rear subframe given all the fiddling about I have done at the rear end (ooer!), how easily does the front one come out? Could I do this on my drive?
Seen any second hand ones then? - actually there are a few on eBay, a beauty of a rear one for £400 ! .
Post #399027 3rd Aug 2016 5:48pm
Front should be fairly easy, you just need a framework across the suspension tops to support the engine... Thumbs Up Pete
Post #399034 3rd Aug 2016 5:59pm
As above Joe Smile
For spares just try breakers.
Not sure if the subframes are the same across years and engines mind. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #399066 3rd Aug 2016 7:48pm
Fester
United States 2017 Range Rover Autobiography 5.0 SC V8 Baltic Blue
Re: Mileage: 170,000
(searched and searched for my "annual thread" .........................................................
Congrats --- that's definitely something!
Post #400336 13th Aug 2016 7:39am
If it's got all new bushes on it then gotta be worth it for that price to save faff with bushes as a direct boot over swap Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #400343 13th Aug 2016 8:51am
kingpleb wrote:
As above Joe Smile
Yes they are Will... All the same exept the later Derv frames have extra exhaust hangers attached Thumbs Up
Post #400361 13th Aug 2016 10:39am
Are the rear diffs the same as well? Extra hangers makemo real odds as you don't need to use them Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #400364 13th Aug 2016 10:48am
Sorry Will, i was referring to the front subframes being all the same no matter what the engine fitment Thumbs Up
Rears I’m unsure about Bow down
Post #400374 13th Aug 2016 12:29pm
johnboyairey
I'm on 166k. All three mots I've done on it since owning, apart from the first, (bought with no mot) have passed, with this year getting an advise on the front discs. (Done) and the under tray had a couple of bolts missing!
I've seen the the paint flaking off the front subframe, but it's not like it's made of tin plate. Surely, it's worth getting your overalls on and goggles, and brushing it up a bit, and perharps brush painting it. Surely you can get to most of it. And maybe an aerosol for the out of reach places.
Shutz guns work wonders. It's cheap, but it does cover other components, if not properly padded with screwup newspaper, or rags etc. Might be a lot easier than removing it all.
There you go, your next job to think out, while soaking in the bath!
Post #400378 13th Aug 2016 12:52pm
MOT guy suggested I went at front and back with an air needle gun to knock off all the loose.
Don't have air compressor, but a "proper" electric one can be had from Jewsons on hire for the weekend for £45
http://www.jewson.co.uk/tool-hire/power-to...eedle-gun/
might be a bit unwieldy in places though... .
Post #400384 13th Aug 2016 1:29pm
How much would it be to sand blast it if you tooo it off the car though as that could only be 15mins work for someone and save a lot of time for you but does mean fully taking it off and you can note the areas to really coat it up as well as I'm sure some bits suffer more than others... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #400390 13th Aug 2016 3:04pm
