Home > Maintenance & Mods (L322) > Lower temperature thermostat?? |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
Take a look in this thread, http://www.fullfatrr.com/forum/topic13318.html
11th Aug 2016 4:56pm |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 |
(link doesnt work ) |
11th Aug 2016 5:21pm |
Link fixed.
11th Aug 2016 5:46pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3183 |
@jamie
11th Aug 2016 6:13pm |
I am assuming that is due to Amazon looking up the official engines it is listed as fitting on a compatibility checker.
11th Aug 2016 6:17pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
For your info, I fitted this kit.
Thanks for the replies and links. Ive read loads through the search facility and have 4 questions:
11th Aug 2016 8:05pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
1. Whichever one you're happy with they both do the same thing, I'm tight so I used the cheapest...
11th Aug 2016 9:34pm |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Great info. Is this a strongly recommended modification? Did I miss it in Wiki? Any down sides to this mod? |
11th Aug 2016 9:42pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
You do need to modify your thermostat housing..........the bit the hose connects too.
11th Aug 2016 9:45pm |
thanks for the quick succinct reply.
11th Aug 2016 9:46pm |
The cut is inside the stat housing, I just mention the potential for damage to sealing face.
11th Aug 2016 9:50pm |
It sounds a bit involved, its not really.......the hardest thing is the bottom inner stat bolt, you need very small fingers and either a high quality 3/8 drive set or 1/4 drive set.
11th Aug 2016 9:54pm |
What that lot said.... plus, there is no WIKI item as it really isn't needed if you do a few bits and bobs on your car and have a basic tool kit you can't go wrong, sealing isn't an issue... it's very easy and simple...
11th Aug 2016 10:01pm |
