Home > General > Fuel tank reserve? |
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 |
I have only tested the reserve tank range once - when I first got the car. The fuel reserve light was on but I kept my eye on the on board computer and I kept going.... The car suddenly came to a stop even though the computer still showed a range of 35km!! Not very accurate is my conclusion! '01 1.8i Freelander. Grey/ grey
29th Nov 2010 1:24pm |
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 |
When i set off from my house on Friday, the Range was -- . Had no problems the few miles to the petrol station, but i didn't brim it. Next time i play the fuel lottery, i'll brim it to find out. Our local petrol station has a max delivery of 95L though. |
29th Nov 2010 1:27pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
So does mine, well that or 99 litres, but once they get used to you filling it up all the time it can be overridden by the staff. I did once put £50 in and they asked why I didn't fill it up. |
29th Nov 2010 1:35pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I just fill mine up when light comes on, which is abour 3 gallons and 54 miles to go. I couldn't risk running it until 0!
29th Nov 2010 1:38pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 761 |
I've pushed 100 litres into my TDV8 and the bill was £119.90. Range was still showing 25 miles or something like that. Never seen the range at zero even though I'm usually tempted to play the fuel light lotto. Most pumps won't go past £99.90 (ish) or 100ltrs on some types, but the most modern ones will happily sail through this as they have a five digit £ display. Not many of them about yet but they will be appearing everywhere eventually. The older I get, the more I realise that people confuse wrinkles for wisdom |
29th Nov 2010 1:46pm |
Do they not use hand cranking pumps in Scotland |
29th Nov 2010 2:15pm |
When I said that I'd pushed 100 litres in, that is of course exactly what I meant.
29th Nov 2010 2:48pm |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
Whilst I never fill until the light comes on, I am too nervous to push for real fuel light lottery. I have also been told that running the tank very empty is bad as it encourages all the dregs to be sucked into the fuel filter. Sounds like BS to me (the fuel feed will be from one of the lowest points in the tank) but I did have a big problem on one of my first Astons as the fuel pumps were very susceptible to damage. |
29th Nov 2010 3:16pm |
I only do it as when the light comes on I can only get about 80 litres in. So I know I can go a bit lower...
29th Nov 2010 3:40pm |
Fox Does it actually say Range 0 ? , as i have only ever seen "Range -- ". I've never been looking to see if it went to zero first. Andy |
29th Nov 2010 4:21pm |
No, --- I take as 0. It does show right down to 1 though sometimes. Other times it jumps from 4 or 8 to ---. |
29th Nov 2010 5:33pm |
It's not a good idea to let the tank run dry, if you do the fuel lines and filters pick up all the crap from the bottom of the tank. I've also read that it can damage the CAT when you run out of fuel. |
30th Nov 2010 4:22pm |
Agreed. But at range 0 it has 10% still left in the tank.
30th Nov 2010 5:28pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, i have the 4.4 petrol and it will run out when it says around 25 miles left, can this be reset to correct it, not that i let it run that low any way... V8 facelift Range Rover Autobiography 22" wheels.
30th Nov 2010 6:13pm |
