![]() | Home > Maintenance & Mods (L322) > More on batteries! |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
Hi, Guys! Does more on batteries turn you on?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8348 ![]() ![]() ![]() |
Sounds like a bad cell to me...
Thanks Pete |
Basically the cells create debris as they age, this falls to the bottom of the battery and can then short one particular cell out, the others still work but one is shorted... |
Thanks again, Pete |
Basically it's calcium deposits on the plates, kind of like limescale in a kettle. Over time these get big enough to fall off and collect at the bottom as Pete said.
That's the sort of thing I'd try, mzplcg!
Yes, johnboy, I believe it does have a regulator, but there was a moment when I suspected the solar panel and wondered whether it had been over-charging. But I bought the panel in the first place as I suspected the battery was not holding its charge well enough - it was below nicedayforit's 'decay values' (http://www.fullfatrr.com/forum/topic29283-60.html d. 06/03/2015) - so I suspect the battery was showing the first signs of weakness even before getting the solar charger.
By the way, I have ordered a Varta Silver Dynamic 110 Ah 920 A, the same as before and from the same supplier (Tayna). 3 years before failure doesn't sound long to me |
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 151 ![]() ![]() ![]() |
Last month had to buy 2 batteries for 2 cars and went for Yuasa Black with a lifetime guarantee fir both. So far no problems and for the money a no-brainer. Current:
Interesting |
