![]() | Home > Technical (L322) > VANOS alignment problem plus seal replacement |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Pete, Johnboy has done this, he'll be along soon with some words of wisdom... |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 ![]() ![]() |
Cheers Pete
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
I've not done this yet so only going by what I've found online and a bit of judgement.
Hi Colin
Personally I don't think you need to worry too much about the alignment despite what is said in some procedures. According to what I've seen and read the alignment is only marked for reassembling because the inner piston is balanced relative to the outer. Ideally you would want to keep it aligned but if you've got into a situation where the alignment is unknown I wouldn't be too worried. The worst that I could see happening is the seals may fail a bit earlier than normal but it could be years before that happens.
Hi Colin
Has anyone got a pressing tool for the M62 TUB unit. I could borrow or buy please ? Eddie the eagle watch out 👀 |
Pete you have PM |
Well folks finally got all the kit today.
Good to hear you're making progress! |
Cheers Wejock for the much needed help throughout this project.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Pepi, I replied to your PM
No problem Pete, do you want to come and do mine now |
Yep I read one of your posts in the past Colin. It would seem that you have run the same race I am now running so to speak Eddie the eagle watch out 👀 |
