Home > Technical (L322) > EAS HELP!!!
Waynetab
United Kingdom 2004 Range Rover HSE 4.4 V8 Galway Green
EAS HELP!!!
Received my iid tool and been playing. Decided to see how high I could raise the suspension, and now its stuck??
Front to centre of wheel is 630mm and pretty much undrivable.
EAS re set not changing anything. Neither is deflate all?
What have I done?? Not Galway but Balmoral green actually
148,000 miles
Post #399291 5th Aug 2016 12:55pm
try and set the heights to original using the iidtool or you might be stuck in extended height mode..theres a how to in the wiki that will help.. ... - .- -.
Post #399304 5th Aug 2016 2:42pm
Waynetab
Thanks Stan, will have a look. Not Galway but Balmoral green actually
148,000 miles
Post #399310 5th Aug 2016 3:04pm
You can ask it to go too high, against the maximum the shock will allow, the bag will try to raise it and explode....
If you want to know the maximum it will go to, jack it up and measure the drop.... You have to leave some drop though or in effect you will have no suspension....
As Stan says, try the how to in the WIKI or a battery reset... Pete
Post #399323 5th Aug 2016 4:50pm
Waynetab
Think I got a bit carried away with the Gap iid tool and have got way out of my depth.
Have managed to get it somewhere near standard height and hopefully locked it, as need the car tomorrow.
Cannot raise or lower it using the switch on the dash.
Will have another try with it after the weekend. Probably go with the battery disconnect. Not Galway but Balmoral green actually
148,000 miles
Post #399340 5th Aug 2016 7:36pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
PM sent http://www.gap-diagnostic.com/
Post #399623 8th Aug 2016 2:21pm
Waynetab
Thanks Patrick, all sorted.
Like I said got a little carried away with my new toy lol
I need to read the instructions and have a little patience. All the time everything was doing what it should be, but because I couldn't see/hear any difference straight away assumed I had done something wrong.
When the suspension is so high it takes a while to notice a drop. Not Galway but Balmoral green actually
148,000 miles
Post #399638 8th Aug 2016 6:09pm
