Home > Technical (L322) > Is 100k to 120k too much on a 2011 4.4tdv8? |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Nope .
2nd Aug 2016 1:12am |
Being rather more cautious I would say the same except that I would want a full dealer service history, I would inspect the warrant history (most dealers can get this) and I would want the LR approved used 2 year warranty on it, which is a problem. That only applies to vehicles up to 5 years old when sold so it would need to be a late 2011. Also I think they can't have over 100k on them when sold.
2nd Aug 2016 7:08am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
My 2004 Td6 has just hit 165k miles and still smooth as nut. Regular oil changes are a must. Had to replace the gearbox at 135k, but apart from normal service items, suspension parts & bushes it just seems to go on and on and on. Tom
2nd Aug 2016 9:35am |
abs66 Member Since: 26 Apr 2016 Location: Warrington Posts: 93 |
Thanks for all the advice, very very much appreciated. I will continue my search with some new criteria ie, main full service history.
2nd Aug 2016 3:39pm |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 345 |
Good luck mate. I've started a tentative search, and being a convert to buying a looked after high mileage car I'm in the same price bracket as yourself. It would be a fairly straight forwards search if I were after a black or silver one.
2nd Aug 2016 5:45pm |
I know what you mean about the black and silver ones being plentiful, but luckily I like silver and swmbo like black and silver so should be ok on that score. I'm kind of partial to the red, firenze I think its called but not many of those kicking about.
2nd Aug 2016 10:00pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1397 |
I had the same question and was advised on here that they fold down as normal. Good luck with the search. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
2nd Aug 2016 10:18pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8204 |
If you don't do many miles, buy the 5.0SC far more reliable and cheaper to fix if it does go wrong...
2nd Aug 2016 10:31pm |
Thanks Rob, that is a relief to hear.
2nd Aug 2016 10:41pm |
