Home > Duckworth Parts > Costings gearbox service parts
lawsey
England 2015 Range Rover Vogue SE SDV8 Corris Grey
Dan
Please supply costings for the following
07 tdv8 Gearbox sump cover ( with gasket if separate), mechtronic sealing sleeve, gearbox filter and 6 ltrs lifeguard oil to match.
Thanks
Steve
Post #397695 26th Jul 2016 7:51am
duckworthparts
Site Sponsor
Hi Steve,
You'd be better off with this kit if you want aftermarket lifeguard oil
DA6085G
£180.00inc vat posted.
http://www.britpart.com/all-parts/da6085g/ You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #397720 26th Jul 2016 9:58am
lawsey
Dan
Do you know if the Britpart sump cover is plastic or metal?
also does it include the mechatronic sleeve?
and
Does the gearbox need setting after a filter change?
Post #398067 28th Jul 2016 3:25pm
duckworthparts
Site Sponsor
Kit comprises of pan assembly, transmission fluid, screws, sleeve & plugs.
i think its plastic... never had one in my hand to check, i'm sure someone on here has fitted on and will be able answer that one for you. You can paypal direct using - www.paypal.me/duckworthparts
Post #398074 28th Jul 2016 3:41pm
lawsey
Mechatronic connection
Does anyone know if I'll need the gearbox reset after unplugging the mechatronic connection? I need to put a new sleeve in when I do the oil and filter
Post #398329 29th Jul 2016 9:25pm
I wouldn't, it'll sort itself out if it needs to, resetting can upset the poor little things..... Thumbs Up Pete
Post #398332 29th Jul 2016 9:36pm
lawsey
Parts have arrived £180 incl vat & carriage. ZF 6 x 6 Ltrs Pan, Bolts & sleeve genuine ZF parts.
Q. When refilling (have pump) the fluid goes in cold, then the level has to be checked with the engine running following there procedure and checked - topped up when hot!! Do i take it for a run to warm it up or will it warm up to correct temperature if just left running??
Post #398858 2nd Aug 2016 4:28pm
Clivefog
You need to run through the shift stopping at each gear a few seconds, this fill the valves that may have drained down. Then with the engine up to temp do it again and with engine running top up, remember it will be hot down there and burnt hair on the exhaust don't smell too good, don't ask!
Post #399594 8th Aug 2016 8:19am
