Home > Technical (L322) > Bloody eas
Bungal
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Bloody eas
suspension errors.
I am getting an error code u2000-67.
Also the suspension error keeps coming up on the dash if I try and change the height.
I have fitted a new compressor, battery and recalibrated the suspension using the id tool
When it errors the height doesn't change, just stays at the selected height and will change height slowly.
The compressor seems to be getting very hot (110c).
I am starting to lose the will to live with this thing.
Help
Post #398519 31st Jul 2016 12:31pm
Sounds like you either have a leak or a dodgy height sensor or could be problems with the reservoir?
Check for leaks first, then sensors. .
Post #398602 1st Aug 2016 12:12am
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
U200067 Code=;
Temperature
sensor voltage
takes too long
to read after
suitable
compressor
runtime
Compressor brush
card temperature
sensor harness
wiring: short circuit
to ground, short
circuit to power, high
resistance
Compressor brush
card temperature
sensor failure
Compressor fault
Post #398606 1st Aug 2016 12:52am
Bungal
Thanks guys.
I have noticed that the gallery pressure drops when at height, is this the reservoir?
Should the gallery be holding pressure all the time?
Tia
Brian
Post #398611 1st Aug 2016 5:16am
