Home > Maintenance & Mods (L322) > Interior Modding... |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Black dash top is on there now |
25th Jul 2016 8:52pm |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
I'd be tempted to make a small cut or two in the parts where it's creasing to relieve the stress, once stuck down the cuts will be less noticeable than the creases Dan
26th Jul 2016 6:53am |
Sleeper Member Since: 01 Jun 2016 Location: Birmingham Posts: 55 |
get some heat on the creased area, it should go really soft, then pull it around.
26th Jul 2016 2:12pm |
The decent dye was about £20 the used dash was £40 and no chance of failure - I tried heating looked lovely then the next morning the creases were back :-/ |
26th Jul 2016 8:03pm |
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 |
You need to use vinyl wrap primer on the edgies it helps it stick
26th Jul 2016 10:56pm |
