![]() | Home > Technical (L322) > [ SOLVED ] Door open message even though doors are closed. |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
Hi all and sorry if this has been done to death but I can't find a definitive answer to this annoying problem.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Open and slam all the doors, boot and bonnet a couple of times, you may find it goes away... If not try a battery disconnect (see WIKI)
Hi Pete, thanks for info but I've tried the slamming of the doors, so much so that my neighbours must have thought PMT was finally kicking in.
Personally I wouldn't have one, the IID is the class leader and does everything the dealer can do and more, the back up from GAP is superb...
Thanks for the advice, I'll have a poke around on the Gap site..... ______________________________
I've decided to go for the IID Tool as it seems to give the best all round performance for the price. The problem still remains with a latch I think, can't check which one as I don't have my IID yet but I did strip down the drivers side today but no change.
Do your indicators flash once when you lock the car with a key fob? |
Yes they do.. ______________________________
Good advice thank you. The suspension is inactive as I can't change the ride height at all. I toggle the switch to say - off-road height and the LEDs just flash and no change in height, even after waiting a minute or so, it's the same with access height on either the door button or the suspension toggle on the dash.
Unfortunately despite what I said above what you say about the air suspension not moving tends to suggest it's one of the passenger doors causing the problem not the tailgate. The tailgate being open doesn't inhibit the air suspension changing height.
Hi, ok so I've just checked the tailgate and it latches securely with no movement at all, I even activated the latches with a screwdriver to simulate it being shut and no difference.
Did you try battery disconnect (often resolves a multitude of sins, resets ECUs and banishes electrical gremlins back in their box (for a while |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
Hi and thanks for the suggestions. I've tried the battery disconnect but nothing changed so I'm just going to wait for the IID to show up.
