Home > Maintenance & Mods (L322) > 2010 conversion questions to those that have done it... |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
have you looked at the wiki entry?
26th Jul 2016 6:43am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Yes I have but that is for an 06+ I have an 02+ - also I was wondering about if you can modify the crash bar as I have read about people theorising you could |
26th Jul 2016 7:10am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
You can use a normal 2002 crash bumper, the 2006 crash bumper was for the 2006 fog lights but on a 2012 facelift the fog lights now sit a lot lower so the crash bar holes are not important anymore
26th Jul 2016 5:25pm |
Matt that's great - do I need the slam panel that sits above the lights and the light brackets I'm seeing some people saying as well? |
26th Jul 2016 8:04pm |
You need everything that is listed in my step by step guide. Not sure what you mean when you say "slam panel" but if it's the long plastic bracket that sits on top of the crash bar then yes as this helps hold the headlights.
27th Jul 2016 10:07am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1534 |
The slam panel is the top horizontal plate above the grille that holds the bonnet catches, etc.
27th Jul 2016 10:20am |
Ah cool, you don't need to change this the 2003 version is compatible with the 2012 facelift
27th Jul 2016 10:28am |
jam220 Member Since: 08 Jun 2016 Location: Atlanta Posts: 31 |
question, i am almost done with this conversion...where did you get the harness for the front lights to work correctly. Im doing this on a 07. |
27th Jul 2016 2:26pm |
It's not a harness you have to cut off your old connectors and solder the new 2010+ connectors from powerful uk. That's the best way to do it to do a good job!
27th Jul 2016 3:16pm |
