![]() | Home > Technical (L322) > center diff lock not working? |
| Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123
Hi.
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1040
The NV225 transfer box fitted to your TD6 uses a Torsen T-2/Type B centre differential. This is a self-contained mechanical unit with no capability of external control.
Sow i guess its broken or else i would have minimum 35% tracktion on The rear/front wheels? -03V td6
As neither of the final drive differentials have limited-slip/diff. locks this means that if one wheel spins then none of the other wheels will receive any torque. The Torsen differential can’t prevent this. The traction control system therefore relies on controlling the application of the wheel brakes to provide enough torque reaction to cause drive to be sent to the non-slipping wheels.
thx rrphil -03V td6
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Yes it's bust, I have all four spinning regularly........ Pete
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215
If you maintained forward momentum I would suggest its working fine.
| Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419
It's highly unlikely the diff is broken, if it was, you would almost definitely hear it!
Thats an excellent example of cross axle stall.
If he has "just" the front or "just" the rear spinning then there is something wrong... no way it can send power just one way if it's working correctly....
The front or rear can just spin if they have no grip, I've seen before on rollers with an L322, however the TC should eventually sort it out. If it's not sorting it out, perhaps because it's not spinning fast enough to do it as per the video above, then it will sit and just spin, that's the way a Torsen diff works.
