Home > Wheels & Tyres > Anyone ever refurbed alloys themselves?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Ive bought a set of L405 alloys for my L322, got them for a great price but there are a few marks on them, nothing serious and they look like theyve been sanded smooth before I got them, so really just need painting/spraying (tiny amount on each wheel - 2 or 3 areas on each rim, no longer than 25mm each area)
Am thinking can I mask it up and spray it, then lacquer it, just the area that needs doing? And are the alloys a 'standard' silver colour, as dont want to spray them the wrong shade of silver/alloy?
Any tips greatly appreciated guys
Post #397393 24th Jul 2016 8:49am
LROMAD
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Hi, if you are planning to spray your wheels, it would be wise to find your local paint /body shop suppliers .They can help you with the paint.I would avoid painting small areas of your wheel ,as it will probably turn out patchy.Give the wheels a good wash before starting the paint preparation process.Carefully preparation and patience will give better results.You can buy wheel silver/lacquer from halfords but colour matching could be hit or miss .As with most paintwork, it boils down to your ability,working environment and time to get good results.Have a look on you tube to get some tips.Just read your post again,it might be possible to just colour the rim and lacquer all the wheel but it s difficult to say how successful it would turn out . Ray
Post #397404 24th Jul 2016 9:43am
mzplcg
Yes I have but definitely not with a rattle can. I use a relatively cheap touch-up spray gun (Sealey) but of course you need a compressor to do this. My results were just fine and as noted above, buy the paint from an auto paint factors.
Patience is also a good virtue when doing such tasks Thumbs Up
Post #397406 24th Jul 2016 9:49am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Sparkle silver Thumbs Up
Post #397440 24th Jul 2016 3:05pm
Clivefog
Done several sets, good rub down finishing with wet and dry. Good clean and you are good to go either to a paint shop or as I did with Hammerite smooth on top of Hammerite primer both from rattle cans and remarks like how much they charge you for that finish says it all.
It is all in the prep and light coats and a wet and dry after any orange peel coats
Post #397450 24th Jul 2016 4:37pm
