Home > Maintenance & Mods (L322) > Air suspension dropping after days of non use |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
You have a s;low leak somewhere sir , time to get a spray bottle of soapy water and look at all the air springs at all heights , in all probability it will get worse and then you will overwork the pump. 2008 MY Supercharged
21st Jul 2016 8:15am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8309 |
It shouldn't drop at all over any period of time.... Pete
21st Jul 2016 12:00pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1386 |
My experience with my 2004 322 was that when it was older it tended to settle down when unused for a week or so, it then raised itself normally when started up, though it could take a while (say 5 mins) to get up to normal height. After that it operated normally and there was no suggestion of a leak from the suspension bags. The back end would lower more than the front, but there was no difference from side to side and it was level in use, i.e. no dropped corners.
22nd Jul 2016 11:46am |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
Take out the fuse and see if it drops. If it does you have a leak.
22nd Jul 2016 3:17pm |
The OP states his DOESN'T drop, he's asking if it is normal for them to drop....
22nd Jul 2016 3:23pm |
