Home > Technical (L322) > BLOODY EAS
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
BLOODY EAS
about to give up and sell this ff ive had new battery,compressor brought two diagnostic tools checked for leaks ,checked voltage on hight sensors ,still getting code 100 invalid articulation Evil or Very Mad Twisted Evil so im thinking i might be calibrating wrong Shocked so my question is ,,,with 19inch wheels what is your ff reading at standard ride,i now they say all ff are different but just a clue where to start as my factory setting was wiped .PLEASE Thumbs Up
Post #396822 20th Jul 2016 10:23am
this will help with your height settings,
Post #396824 20th Jul 2016 10:32am
just a thought, if you have a gap iidtool then you can revert to original settings as these are logged on the tool when you first use it.. ... - .- -.
Post #396826 20th Jul 2016 10:34am
vmaxer
bloody eas
thank you sir Bow down Bow down Bow down Bow down Bow down settings lost before i got iid tool Sad
Post #396836 20th Jul 2016 12:10pm
vmaxer
just rechecked eas this is what came up with iid tool..live value current height FL- 20 FR 20 RL22 RR-18
LIVE VALUES ECU CALI AID FL198 FR 198 RL 185 RR 185
MEASURED HEIGHT FL 530 FR 530 RL 530 RR 530 Confused CAN ANYONE MAKE SENSE OF THIS I CAN,T Big Cry Big Cry
Post #396858 20th Jul 2016 2:32pm
If you work your way through the IID instructions to calibrate your system then it tells you exactly what to do, those figures mean nothing on their own, they just show the readings from the sensors...
What fault codes are you getting from the IID tool when you read codes from the EAS system...??? Pete
Post #396862 20th Jul 2016 3:09pm
vmaxer
Hi pete code reads 1/1 0x64 mean anything.
Post #396879 20th Jul 2016 5:09pm
That's a code they all seem to have, means nothing... what's the problem then??? Pete
Post #396913 20th Jul 2016 8:32pm
vmaxer
clear faults move 30yards suspension locks invalid articulation fault go on motorway over 50mph its very twitchy when sitting on drive it looks to high but stays level Big Cry
Post #396951 21st Jul 2016 8:35am
You need someone with some experience to check the live values on the move to determine where the fault lies...
Or change all the height sensors which will PROBABLY sort the problem.... Thumbs Up Pete
Post #396972 21st Jul 2016 11:55am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi Guys
The ECU does not actually try to get the vehicle straight. It tries to average out both sides.
These indicates that the calibration is way off and that the ECU is not able to reach or get close the target (0...) for any corners. This explains the articulation fault
Calibrations are never equal since they are dependent on the mechanical positioning of the sensors themselves.
Send me a PM and I will give you a hand.
Cheers http://www.gap-diagnostic.com/
Post #397629 25th Jul 2016 6:23pm
