Home > Maintenance & Mods (L322) > Front Wheel bearing
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Front Wheel bearing
I've done a search and read the post about needing a press to change out the front bearing,So i've done a bit of google work and looked at various things , my question is whether or not a RRsport front bearing/hub assembly is the same as the vogue assembly as these can be had for a reasonable price and would be easier than /cheaper than getting a garage to do it L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #396406 16th Jul 2016 7:11pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Unfortunately the rr sport is a complete hub assembly, whereas the l322 is a separate bearing, the stub has to be pressed or pulled out first then the circlip removed, and the bearing pressed from the hub assy.
so sorry the rr sport bearing assy will not fit.
Post #396412 16th Jul 2016 8:27pm
Mikey
And the shaft is tapered into the hub, and can be a right Censored to remove.
My 12 Ton press struggled with the last one I done Big Cry
Post #396419 16th Jul 2016 8:53pm
Ivor
How annoying do they have to make simple things guess I'll be having a chat with a local specialist
thanks for the info L322 2008 vogue
Post #396420 16th Jul 2016 8:55pm
