Home > Finance, Insurance & Warranties > curious
curious
i have a 2 year LR used car approved warranty so if i had my auto gearbox oil and filter changed would this void my warranty.. ... - .- -.
Post #396201 15th Jul 2016 12:23pm
mzplcg
As long as you use the correct fluid adn genuine LR filters etc I don't see how they could. There's EU rules on this kind of thing.
Post #396202 15th Jul 2016 12:28pm
my worry Dom is that if i did an oil/filter change and some part which is associated with that went wrong ,the warranty wouldnt be valid ... - .- -.
Post #396203 15th Jul 2016 12:31pm
pld118
What does the maintenance schedule say about if/ when that should be changed Stan?
And either way, if you had it done at other than an LR garage, how would they know (in any event, as one example, are VAT registered garages not allowed to do work provided genuine LR parts are used... Or does the policy wording preclude that)?
And and and... Is it not a similar principle to all of those who do preventative maintenance like DIY changing the transfer case fluid and front and rear diff oils etc because those parts are all covered under warranty Question
Post #396204 15th Jul 2016 12:32pm
being a sealed box?i dont think its in the maintenance schedule Ryan..could be a minefield. Neutral ... - .- -.
Post #396208 15th Jul 2016 1:06pm
johnboyairey
.....understand how you feel, Stan.
you could almost wonder, if you are allowed to wash it, with unapproved shampoo! -and if no-one was looking, could you jetwash the wheels.
....certainly not allowed to open the bonnet. thats too technical. Shocked
Post #396210 15th Jul 2016 1:14pm
wealy
My girlfriend had a problem with her washer jets blocking up on her BMW 1 series and the dealer would not sort it under warranty as they said it was not BMW approved washer fluid that she put in!!! Sad
I went into battle with them and said that she has never lifted the bonnet on the car (as she doesnt know how to) so how can she have put non BMW fluid in? They eventually sorted it and I found out it is a common problem on that model due to the position of the tank.
Dealers will try and crawl out of anything if they can find a reason. I wouldn't risk it Stan, well not yet anyway.
Post #396213 15th Jul 2016 1:32pm
interesting....
my thoughts are that the warranty will mend mine if something goes wrong so preventive maintenance might be an un- necessary expense. ... - .- -.
Post #396215 15th Jul 2016 1:52pm
wealy
How many miles has it done? When I changed mine it was about 80,000 miles and I wished I hadn't bothered after I did it as the oil was fine that came out. I think if the car has done a bit of towing its important to get it changed.
Post #396224 15th Jul 2016 2:38pm
hasnt towed and its at 70k miles ....i seem to remember when i had my 2008 done at craigs that when the oil came out it looked ok.. ... - .- -.
Post #396226 15th Jul 2016 2:48pm
