Home > Maintenance & Mods (L322) > Best 4.4 v8 come filter?
Danwilderspin
Looking at different mods for up front and I see some say the stock air of needs removing and swapping out for a cone - are there any better than others?
Post #395531 11th Jul 2016 5:28pm
johnboyairey
When you do a mid range facelift, (maybe late-lift too) you have to junk the v8 air filter. ( don't know the td6) so there is slightly limited room, so you typically fit a universal cone filter, like a k&n type. Although you can get them for £10 this means you are now up and running. There is a spare pipe that you then find a miniature universal cone filter, and fit it on the pipe, as you can't typically plumb it into the old filter housing. This sits verticle near the rad. The new larger cone filter sits high facing the inner wing, it also needs a small stay bracket, to be sure it doesn't shake loose. You WILL get increased induction roar, when you pull away to overtake etc. Sounds nice, but it does sort of spoil the 'waft' of driving the Rangie around. It a small price to pay though for an updated look. I did mine as my headlights were falling to pieces inside. Mid range headlights are very affordable. Late ones are mega bucks.
Look for a colour coded bumper and have it shipped, to save you spraying one that is locally sourced.
There are how-to's on face lifts on this forum.
Post #395557 11th Jul 2016 8:56pm
espaceboy
RF-1031 K&N
Post #395567 11th Jul 2016 9:21pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I used a Pipercross C0640 which fitted very neatly and cost about £42.50. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #395663 12th Jul 2016 12:00pm
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
who needs waft anyway John, growls and smiles all the way haha Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #395667 12th Jul 2016 12:12pm
chex
Kenya
I use an AEM dryflow filter, it's oil free and doesn't kill the MAF 2004 L322 V8
Post #395668 12th Jul 2016 12:17pm
Danwilderspin
Can you run a bmc cda on it or piper cross viper? I prefer those styles and you can get proper cold air without heat soak
Post #395672 12th Jul 2016 12:32pm
i'd change your title before some one gets the wrong idea.. Laughing ... - .- -.
Post #395673 12th Jul 2016 12:38pm
Danwilderspin
Oh yes didn't even notice that![/u]
Post #395674 12th Jul 2016 12:51pm
Dolphinboy
BTW the RF-1031 K&N filter is over £60 on Fleabay and others. I got one recently for £7 off amazon. go figure??!! Shocked
Post #395675 12th Jul 2016 12:58pm
Danwilderspin
I've been looking at the BMC CDA as i have used these before not sure if its an issue that the inlet is smaller than the outlet - this is by design but surely this restriction couldn't be good?
Post #395735 12th Jul 2016 8:32pm
