Home > Technical (L322) > TD6 Turbo removal
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
TD6 Turbo removal
I have seen the overly complicated diy on you tube but have also read its much simpler with access from the top via removing blanking plugs from under the air filter. My question is has anyone actually done it on here, if so is it easy to do by dropping the exhaust to get room to drop the turbo out once undone. Is there a good write up with pictures, I cant find one.
I am asking as if its an easy enough job I would remove mine just to give it a total clean of the variable vanes and a re core, if not I will leave well alone. The turbo has done 210000 klms I presume thats getting long in the tooth so this would be preventative maintenance not desperate. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #394998 8th Jul 2016 8:32am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Their is a good write up, but I think on another forum, iirc it was quite detailed.
Post #395097 8th Jul 2016 6:39pm
