Home > Maintenance & Mods (L322) > help, anyone with IID tool in Bristol avail for EAS reset
Dolphinboy
Hi guys,
Anyone in Bristol Area able to let me come and use their IId tool to Re-set suspension?
Just had a puncture repaired on rear N/S wheel and the guy jacked up the car using the rear left wishbone, leaving the Passenger door ajar.
On picking the car up, as I drove off, the EAS light came on and warning bong "air Suspension inactive" comes up.
v annoying as this is the first time ever the EAS has had any issue! Have tried the old left to right re-set to no avail.
Many thanks
DB
Post #394411 4th Jul 2016 3:21pm
Clivefog
You are welcome to try mine, not had to use it in anger yet would be interesting.
Post #394417 4th Jul 2016 3:40pm
Goldy
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Would that not be VIN locked to the owner?
if so would be £25 to change to your vin and then £25 to change back.
Properly still cheaper than taking it somewhere though.
Post #394421 4th Jul 2016 3:52pm
Have you tried a battery disconnect...
If not the IID should do it, no vin lock for reading and clearing faults only need registering for CCF adjustments... Thumbs Up Pete
Post #394422 4th Jul 2016 3:56pm
Dolphinboy
Thanks for your help chaps.
@Clive - That's very kind. Will pm you.
Thanks Pete - tried that and no luck. put a brand new battery in at the same time!
Post #394445 4th Jul 2016 4:46pm
Clivefog
And reply sent back.
Post #394467 4th Jul 2016 6:34pm
Clivefog
Nice to have met you James.
Also good to see the OBD reader put to use and appear to clear the fault.
If you need it any time you know where I'm to. (Sorry a bit of West Country speak even though I'm a London boy)
I'd be very interested in that wheel provided it has holes and not dimples between the wheel nut holes.
Post #395004 8th Jul 2016 10:39am
Dolphinboy
Hi Clive,
Many thanks for your kind help. Will look out the wheel for you.
Sadly the EAS light has come up again so I will have to look at the fault code to see what's amiss.
best,
James
Post #395019 8th Jul 2016 11:56am
