Home > Camping, Caravanning and Holidays > Roof Rack Options - Wise guidance required
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Gents
I'm looking at roof rack options for my full fat as we are about to go camping and the dog and children's kit takes most of the interior space up. We have a bike rack on the tow bar so that's out. At the moment, I'm looking at the Thule options and the sports bars that I understand bolt into the roof fixtures. I read somewhere that the box hangs of the back with the sports bars on and someone told me the Thule racks have potential issues with not being a good fit.
Any thought gratefully received!
Post #393980 1st Jul 2016 8:57am
I'm a Thule fan - I did 1000's of miles with them on mine in various combinations of 4 bikes / kayaks / roof box / skis & snowboards with no problems at all.
I didn't want anything permanent - and wanted them to lock to the car.
I though they were a good fit - and all their other kit fits properly & locks to their bars Thumbs Up
Post #393985 1st Jul 2016 9:49am
Jase71
Thanks Alistair. It's interesting as I found a place to hire the thule racks and a roof box to save them sitting about and they told me they have added the L322 RR to the 'no fit list' which doesn't make sense to me as the Thule website lists it!
Anyway, how did you find the clamps adjacent to the door rubbers? Did they mark the roof etc?
I thought the sports bars looked good but I'm not sure if you have to break the little covers for the roof fixture points?
Post #393986 1st Jul 2016 9:52am
I worried at first. but mine didn't mark - I placed them towards the rear of each door arch & they seemed fine - the door just closed & the rubbers just flex around them.
I've seen some people put a rag between them & the body work, but I thought that would just make for a poor fit
Post #393988 1st Jul 2016 9:58am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I can't remember who it was but someone on the forum posted about this a while back that they used the Thule system that goes into the hidden fixings, saying that it fitted well even though Thule don't have it their fitting list. Maybe my memory is awry but I seem to recollect that fitting didn't require snapping of the fixing covers either.
Perhaps best to wait a bit to see if that contributor sees your thread.
Post #393996 1st Jul 2016 11:19am
Better in every conceivable way than Thule Thumbs Up Wink
http://www.rhinorack.co.uk/Vehicle_LAND%20..._4101.aspx 2008 MY Supercharged
Post #394016 1st Jul 2016 1:55pm
Jase71
Very nice Axle but priced to match!
Post #394017 1st Jul 2016 2:30pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
For what its worth I have the genuine LR sports bars and they are excellent quality. The fitting is a bit of a fag but once fitted they feel like they could carry the town hall.
Only issue is they are fixed positions so am not sure how this interacts with some roof boxes. Other than that if you suspect you will ever need to transport a dead elephant or small aircraft these are the ones for you!! Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #394022 1st Jul 2016 2:45pm
Jase71
Thanks Ajac8. I quite like the Sorts Bars too as they attach to the roof fittings..Did you have to remove the little fitting covers on the roof? I've heard some require the covers to be cut off which would mean they are permanently mounted!
I wonder if a roof box would fit with them on?
Post #394025 1st Jul 2016 2:49pm
Elduke
Scotland 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
AFAIK the sports bars can be fitted with the flaps remaining just opened up.
I had the genuine track system and it requires the flaps to be removed probably where the confusion is.
Also I believe it is possible to fit three sports bars by getting two sets and cutting one down to fit as I've seen them being sold in 3s which others have did.
Post #394243 3rd Jul 2016 10:43am
ajac8
The little flaps pop up easily and remain vertical on the inner side of the bar foot. They can be a bit fragile but do not need removing. They simply click back down into place after the bars are removed.
The roof bars are not the same length as the middle fixing point is wider than the front. I've not tried which bar fits the rear but I bet its one of them - I cant ever see LR producing roof bar that needs 'cutting down'. A simple measurement should suffice. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #394428 4th Jul 2016 4:09pm
I have a set of sports bars and they are easy to fit, each foot simply has a Torx screw which screws into a threaded hole in the roof. Dead easy.
100% the flaps can stay Thumbs Up I think the roof is narrower at the back than the front so a third bar will probably need trimming. Shouldn't be difficult to do though.
I got mine 2nd hand off here and a wanted ad would be a good idea, if not then EBay. There is nothing that can't be fixed with a hammer😜😜
Post #394443 4th Jul 2016 4:41pm
Dolphinboy
@Jase71,
I have a set of the original LR roof bar going spare (I have roof rails which take a different type of bar). they don't have working locks IIRC, but then if anyone wants to get your rack off, they can easily do it anyway even with locks.
They may do as a short-term solution for your hols.
PM me if you are interested. Am Bristol based.
DB
Post #394449 4th Jul 2016 5:00pm
Jase71
Ah Dolphin Boy, that is hugely kind! I bought the thule ones with the aero bar on the weekend and I've only just seen your kind offer..%^$% !!
I manage to borrow a mates roof box so I'm still pretty happy. Just need to prep the fullfatty for its adventures now.
Thanks again.
Jase
Post #394508 4th Jul 2016 8:31pm
Again if you want three bars you have to get the rhino Rack sports bars because they are the only ones that are adjusted for height and width so you can have a flat run to fit trays and the like . 2008 MY Supercharged
Post #394536 5th Jul 2016 2:02am
