Home > In Car Electronics (L322) > Key synching on 2007 key
Sandyt
Anyone know if there is an easy way of resynching keys I have one that doesn't work on the buttons tried the sequence from searches but doesn't seem to work?
Post #393939 30th Jun 2016 9:13pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
I had to do mine after a battery swap
Programming a new Key
Replacing a missing master key is quite expensive from Land Rover, try not to get sucked into the extra cost of "Dealer coding" You can do this yourself in 2 minutes by following the simple process below.
1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize.
Post #393983 1st Jul 2016 9:27am
Weegie
Just one amplification, between stages 2 and 3 above DO NOT put the additional key in the ignition (stage 1) as this starts the whole process again. John
GAP iiD BT
Post #393998 1st Jul 2016 11:30am
