Home > Technical (L322) > Mini blade fuses with red LEDs - am I late to the party? |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 |
Bought a mixed box of mini blade fuses today from Halfrauds as I knew a few of the things in my car that weren't working (cigar lighters etc) were most likely to be fuse related.
30th Jun 2016 12:12am |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
but who doesn't love faffing? Dan
30th Jun 2016 10:58am |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
You're slightly late to the party, buffet hasn't been served yet though
30th Jun 2016 11:00am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
I would assume that the LED (with its voltage reducing resistor is wired across the 2 blades. When the fuse is good, then both sides will be either 12v (nominal) or 0v. If the fuse blows, then the ends of the fuse are different voltages and the LED light. The dropping resistor will also act as a current limiter |
30th Jun 2016 11:42am |
No idea how they work. I was going to say automagic - but Berkshirelad's answer is probably slightly more accurate.
30th Jun 2016 1:49pm |
Just as an FYI there seem to be two types. Cheaper ones have the LED protruding out of the top of the fuse, the ones I have look exactly like standard fuses with the LED built in. Past (too many to list, but a few favs)...
30th Jun 2016 2:03pm |
Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48 |
Surprised halfords sell um. Bet they are expensive.
30th Jun 2016 5:32pm |
