Home > Technical (L322) > P2105 throttle body
FleXzoR
Belgium 2016 Range Rover Autobiography SDV8 Santorini Black
P2105 throttle body
Hello over here
Some weeks ago i did a maintenance on my supercharger. I also removed the throttle body and cleaned the carbon.
Today and yesterday, when i put the gearbox in 6th, driving at low speeds (70km/h) and floor the throttle (so 1000-1100 rpm), i get the engine fault message. The engine goes in to limp home. After restart everything is fine
The fault i get is P2105.
What can be wrong?
Thanks MY2008 Buckingham Blue Supercharged - gone
MY2016 Santorini Black 4.4 SDV8 LWB AB
Post #393652 29th Jun 2016 4:10pm
any help?
http://www.autocodes.com/p2105.html ... - .- -.
Post #393653 29th Jun 2016 4:15pm
FleXzoR
Thanks for the information.
I found out that, when i put it locked in 5th or 6th, and start flooring it at 1100rpm, it slowly rises rpm.
When the rpm starts to build up and at, 1200-1400rpm i stop flooring it immediateley, i get the fault code.
I think my throttle body can't follow the signal coming from my accelerator pedal.. Weird.. Will have a closer look at the throttle body this weekend.
Anyone some more hints?
Post #393673 29th Jun 2016 6:08pm
If you forced the throttle body open when you cleaned it then this can seriously damage the internals.... Pete
Post #393701 29th Jun 2016 7:52pm
FleXzoR
I forced indeed the throttle body for cleaning.. Although did not had to use alot of force... MY2008 Buckingham Blue Supercharged - gone
Post #393702 29th Jun 2016 7:54pm
Very delicate item, not designed to be opened against the motor, worth seeing if there are live values available to monitor it working... Pete
Post #393710 29th Jun 2016 8:12pm
FleXzoR
Strange i do not have any other problems despite the problem i mentioned. In normal drive nothing noticable. Only a bit judder at idle sometimes.. Changes spark plugs allready MY2008 Buckingham Blue Supercharged - gone
Post #393711 29th Jun 2016 8:18pm
