Home > Technical (L322) > 4.4 tdv8 hesitation at 80 mph'ish
Page 1 of 4 1234>
done a search but cant find the thread that someone mention a momentary judder/hesitation at around 80 mph,...can anyone help or enlighten me to why this is happening ? ... - .- -.
Post #393610 29th Jun 2016 12:02pm
Baltic Blue
Just a guess, but if it coincides with the opening up of the second turbo, then check that the air change over valve is not sticking slightly.
It might be worth checking if you have the modified valve just in case.
My 2011 valve was changed under LR approved warranty because it stuck.
Post #393615 29th Jun 2016 12:30pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Ahem... the speed limit round these parts is 70 Embarassed 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #393617 29th Jun 2016 12:47pm
Weegie
It obviously occurred when Stan was returning through Europe from his holidays. Very Happy Very Happy John
GAP iiD BT-Sold
Post #393623 29th Jun 2016 1:16pm
thanks for that Michael.. Wink
Ade, you're correct re the speed limit in these parts but this was on the froggy autoroute where the speed limit is 81 mph [130 kph] Ner Ner ... - .- -.
Post #393624 29th Jun 2016 1:18pm
Thumbs Up John.. ... - .- -.
Post #393629 29th Jun 2016 1:47pm
Mactech
England 2012 Range Rover Vogue TDV8 Buckingham Blue
I h-h-h have never h-heard of the problem, nor experienced it... Embarassed 2012MY Range Rover 4.4 TDV8 Vogue...now gone!
2007MY Mercedes C200 Estate 'Albert'
1997MY Defender 90 TDI 'Vera'
Post #393667 29th Jun 2016 6:21pm
Rolling Eyes Laughing Wink ... - .- -.
Post #393684 29th Jun 2016 7:58pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Momentary hesitation...
There was a technical bulletin....a software release cured the problem.
Post #393698 29th Jun 2016 8:36pm
interesting, have you the tsb number rambles? ... - .- -.
Post #393715 29th Jun 2016 9:35pm
Can't find it either Stan but there is a TSB for it and it's listed on topix👍
Had a look and it's a PCM update (power train control module)
edit I knew i had typed it in somewhere....LTB00054v2 There is nothing that can't be fixed with a hammer😜😜
Post #393725 29th Jun 2016 10:14pm
thanks Mark..i was told by the dealer that all updates would be done prior to my collection but i took that with a pinch of salt.. Thumbs Up ... - .- -.
Post #393763 30th Jun 2016 7:05am
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
does anyone know if this can be done with the IID Tool, or if its main dealer only, mine does it and at high speed when you lift off its really disconcerting and annoying.
Thanks
Post #396409 16th Jul 2016 7:35pm
had mine done by the dealer under warranty but not had a chance to see if its still there.....pretty sure the iidtool wont do this update... ... - .- -.
Post #396416 16th Jul 2016 8:39pm
Trantorman
Thanks Stan,
Do we have a note of the upgrade reference number at all?
Post #396448 17th Jul 2016 8:46am
Page 1 of 4 1234>
