Home > Maintenance & Mods (L322) > Door card change
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
Door card change
Hi all,
I am looking at getting the seats on my car refurbed as they are showing there age. The door cards are also showing their age, particularly the leather arm rest / door pull. My car has a sand interior and the arm rest is sand as well. The drivers door has also had a previous repair at some point in the past. I have seen a full set of door cards on flea bay but they are off an SE and are sand and black with black arms rests.
What do you guys think about the change? As other partsof the trim are black I thought they may work and with the black handles will not show dirt / age as obviously.
Thanks.
Post #393169 26th Jun 2016 4:36pm
Sounds like a good idea to me, as long as all four are the same it should look fine.... Thumbs Up Thumbs Up Pete
Post #393177 26th Jun 2016 5:08pm
RR2008HSE
I priced a new door card because if some slight wear. After recovering from hearing the price quoted, I went off the idea quickly. It's a nice idea, but I guess it depends on source of parts, cost, budget and how bad they are to start with. Good luck.
Post #393198 26th Jun 2016 7:55pm
Fish
Unfortunately this set of cards won't do, after looking more closely they are from an earlier model. The ad has the wrong model year info. This full set is £250 so a much more affordable option than new ones.
I will keep looking Very Happy
Post #393212 27th Jun 2016 5:18am
Sleeper
United Kingdom 2003 Range Rover HSE 4.4 V8 Adriatic Blue
why not get the seats and dye your current doorcards to match?
Post #393290 27th Jun 2016 6:41pm
Did a 2007 TDV8 last year, had parchment...
Wasn't too bad, I have repaired much worse, it's amasing how good you can get it with some work
Before
After
Seat, before
After
Just done a rather tatty Jaguar X type as well...
Before
After
Before
After
Just make sure the place that does it uses adhesion promoter, hardener in the top coat and uses the correct finish, a lot shortcut and just use colour.... :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #393306 27th Jun 2016 8:08pm
Fish
They look great, hopefully I can get mine looking something like that 😀
Post #393324 27th Jun 2016 8:54pm
Sleeper
Expanding on what Hayland said (great work)
most important part as always is preparation...skimp on that and results will be short lived.
Adhesion promoter is not always needed on leather, especially warn leahter but it does add extra insurance for little cost.
Decent dyes have bulit in sealer but the addition of an top coat sealer allows for extra rub, cleaning before you get down to the colour, again not always needed but give extra protection.
Biggest thing is using a water based cleaner, never only just wipe over with a chemical based cleaner. The disbursing of the water+ cleaner gets into the pores, creases and cracks.
With a lot f Range rover seats having leather faces and vinly sides you will need Adhesion promoter if you are applying dye to vinyl (water based dyes as most are now)
Many types of dye around but alway got for once thats matched to your interior, dont both with the self mix fro scratch kits unless your good at doing that.
Go for one with toners if touching in, so main dye the colour f your leather and toners if you need to lighten or darken to "shade"
All leather changes shade/tone so there may be a bit of variation. But what you end up with is usually a lot better than what you started with.
Oh and never use filler on the seats to fill creases or cracks , you will regeret it.
(sorry if spelling is bad, been a long day)
Post #393547 28th Jun 2016 10:31pm
AFAIK all FF's have full leather on all the seats, including the sides, no vinyl... Pete
Post #393672 29th Jun 2016 5:55pm
Sleeper
It depends on the spec.
Some have full and some have leather faces and vinly sides.
Post #393705 29th Jun 2016 8:00pm
Maybe the SE,HSE seats have vinyl sides , don't know never seen any in the flesh but since the beginning all Vogues and over have been all leather , front back and sides. 2008 MY Supercharged
Post #393760 30th Jun 2016 1:15am
Sleeper
That sounds about right.
Post #393941 30th Jun 2016 9:16pm
