Home > In Car Electronics (L322) > Reversing camera not working on 2006 s/c
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Hi
My reversing camera on my 2006/07 s/c has a very poor picture/ no picture ,checked all connections / plugs at rear camera
So i can only assume , that the camera is faulty,i would like to replace the camera , but keep it in the stock position, what has
Everyone done / recommend, has any one used this guy on ebay who repairs your camera, he puts a new camera in your
Housing see ebay item eBay Item No. 122006076686
Thanks 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #393367 27th Jun 2016 10:19pm
Ollie_247
United Kingdom 2007 Range Rover Vogue SE TDV8 Orkney Grey
Hi Steve57,
My 2007 has also decided to play up this week and by the looks of it you can get the new uprated camera for a lot less then £160 with a new loom and mount.
see the thread below this one. The MOT Track days Test Dummy
2007 Vogue SE TDV8
Post #393779 30th Jun 2016 7:56am
STEVE57
Hi
See thread below ??? 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #393781 30th Jun 2016 8:07am
Ollie_247
Woops forgot to paste it
http://www.fullfatrr.com/forum/topic11302.html
its also below this one as well. The MOT Track days Test Dummy
2007 Vogue SE TDV8
Post #393783 30th Jun 2016 8:16am
STEVE57
Ollie
The new camera , mount & cable from a 2010-2013 has to be mounted id a different position to the 2007 camera position,
Approx 7 cm from the original and then you have to cut/ drill holes for cable and the mounting of the camera, 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #393784 30th Jun 2016 8:20am
STEVE57
hi ollie
looked into replacing the camera with the 2010 one but , due to the hassle of re fitting in a different position, i am thking my camera to the guy who is on ebay he has a company who deals with high end reversing cams,etc he uses your case puts in a complete new camera so its plug and play , and goes back in original position , i have spoken to him on the phone, he is doing it for £150, its only £25 more than a new 2010 cam, but you do not have the hassle of repositioning the cam 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #393790 30th Jun 2016 8:41am
Ollie_247
in that case your rite
discount for doing Two Smile The MOT Track days Test Dummy
2007 Vogue SE TDV8
Post #393794 30th Jun 2016 9:13am
STEVE57
Ollie
I have taken my faulty camera to the guy on ebay at
Vehicle installation sollutions, i should have it back tomorrow
I will keep you informed 😀 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #393842 30th Jun 2016 12:54pm
STEVE57
Hi every one got my reversing camera back from being repaired updated,
The old camera was removed, new camera fitted into original camera housing complete with new wiring loom that plugs into your original wiring loom , so its plug and play you also have the option of reversing lines or you can snip a loop of green wire to not have the reversing lines,see pictures
Post #394020 1st Jul 2016 2:42pm
STEVE57
camera now fitted back in , all working fine 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #394164 2nd Jul 2016 5:42pm
Ollie_247
my camera has just come back after me taking ages to remove it from the car. Brilliant service from Neil.
saves loads of hassle for me. The MOT Track days Test Dummy
2007 Vogue SE TDV8
Post #413069 11th Nov 2016 10:25am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
What's his eBay ID or item number please? 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #413107 11th Nov 2016 4:40pm
forever
Still very pricey, you can fit the same camera for under £10.00, with a little bit of effort, follow the guides on here, super easy
Post #413110 11th Nov 2016 4:51pm
Ollie_247
I just called him and did it over the phone.
Neil - +44 7969 585292
It's pricey when you have the time and electronics skill to sit doing it all.
I on the other have non of those my times premium and it suited my needs was back with in a few days would have taken me weeks. The MOT Track days Test Dummy
2007 Vogue SE TDV8
Post #413761 15th Nov 2016 6:16pm
