Home > Technical (L322) > Heater Blower motor woes!
Turnover
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Hi decided to change the heater blower motor after it had failed. Over several weekends I have managed to get to it after following some past threads. This being a 2007 model meant that in theory there is no cutting to be done. However I can't work out how to get the motor assembly out of this space without using a hammer or more importantly getting the new one in without damaging it.
Any suggestions appreciated!
Cheers
Chris Thumbs Up 2007 Range Rover Supercharged in Zermatt Silver with Jet Leather
Post #392999 25th Jun 2016 3:28pm
andygts
Can you not undo the fans and leave them in the cavity? You'll only have the tiny motor to pull out then. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #393004 25th Jun 2016 4:11pm
Turnover
I'll take a look at where the fans are fixed on but yes it is the fans that are catching on everything. Cheers 2007 Range Rover Supercharged in Zermatt Silver with Jet Leather
Post #393009 25th Jun 2016 4:37pm
