Home > Maintenance & Mods (L322) > Strange wind noise at speed
Dieterf
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Mine just started doing it after windscreen replacement, so i assume the trim is not fitted correctly. I cant see anything untoward, so going back to the fitment center to remove and refit.
Post #392609 22nd Jun 2016 8:22am
mr_spock
Before they cover it in sticky stuff, see if the A pillar trim is loose, and hit the screen base trim with the palm of your hand all the way round to seat the clips.
Post #392613 22nd Jun 2016 8:52am
Knightmare
England 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Yep same thing happened to mine. Autoglass guys didn't stick the scuttle trim in place when they fitted the new screen (happens a lot apparently). If it's not stuck down with adhesive, it vibrates at speed causing a noise in the cabin. Its not noticeable at low speed so fits with your issue. Might have come unstuck? Life is what happens while you�re making other plans.
Post #392636 22nd Jun 2016 12:29pm
Dieterf
Just been back to them.
The bottom rubber strip seems to have been the culprit, was loose and ever so slightly peeled away from the windscreen.
Attended to it promptly and i just did a 140km/h blast to check- ALL OK Thumbs Up
Post #392646 22nd Jun 2016 1:40pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
have a look where the leading edge of the front wing meets the bumper. about 2.30pm if the front wheel was a clock face.. these can part and cause the humming. just needs the wing gentlly pushing back behind the bumper. sorted it for me Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #392656 22nd Jun 2016 2:59pm
