Home > Technical (L322) > Do I (should I) have a secondary air injection pump?
Lenb
England 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Whilst looking at fuses in engine compartment fuse box, I noticed a 'missing' relay! Further research and it turns out its for the 'secondary air injection pump' (SAI) - but I can't find the pump or associated pipe work. Should it be there? Has it been removed? (and if so what damage can it cause by being removed?). Perhaps another reason for poor starting when hot, or O2 sensor fault.
Thank
Lenb Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Previous: 2000 P38 DHSE - 1995 P38 DT Man - 1990 3.9 SE Classic, 1980 3.5 Classic 2dr
Post #392524 21st Jun 2016 2:37pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
According to this it's not fitted or was originally meant to be fitted but removed:
http://www.rangerovers.net/forum/6-range-r...004-a.html
Secondary Air Injection is only there to inject air into the exhaust on cold start up to aid CAT warm up times. In other words it's there purely for emissions. It can be ditched, I've done it before on another track car.
I actually re-instated on another car to bring it back to factory spec, the new pump on that would only run for one minute on start-up...it's a lot extra stuff to go wrong for very little gain!
Post #392528 21st Jun 2016 2:57pm
Lenb
Weejock
The fact that I can't find 'anything' - pump or pipe work - seems to suggest it's more than a 'let's just remove the relay' by someone, does suggest it maybe wasn't there in the first place. I just happened to spot it on my relentless search for 'little problems' with my vehicle that are just taking the edge off ownership Smile
Thanks Thumbs Up Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #392529 21st Jun 2016 3:05pm
