Home > Technical (L322) > Transmission control module fault after service
Mann3210
Scotland 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hello, I'm looking for help with my Supercharged RR, I had the gearbox serviced due to the oil pan gasket was leaking & also had the Tyre pressure system reset. I picked up the car & driven about 15 miles home parked up all fine. Went to start the car to have transmission fault, selective gears only, HDC fault & auto parking brake unavailable. So I called the RAC who checked the car & came back with the TCM is not responsive. He checked other things & then moved the gear shifter from P to D then back again & the car started! Went about 3 miles down the road & all the warnings came up & limp home mode kicked in! Any ideas or is this a common fault?
Post #392450 21st Jun 2016 6:39am
Mann3210
Turns out there was a small wiring issue which the garage put right free of charge! All is well again! 😂
Post #392570 21st Jun 2016 11:30pm
